AVS › AVS Forum › Gaming & Content Streaming › Portable A/V › Swivel/Pivot wall mount for TV or monitor
post #1 of 5
So I have a great setup with my actual TV. Unfortunately due to the layout of my studio, I am unable to watch TV from my bed. So I had the idea that near the foot of the bed, on the right wall I can put a mount and put a TV or Monitor or whatnot (hooked up to a roky or raspberry pi) and leave it flush against the wall, but when I go to bed I can pivot it 90 degrees so it will face me as I watch from the bed. Are there any recommended mounts I can use for this?
post #2 of 5
Any takers?
post #3 of 5
post #4 of 5
Deleted!
Edited by cmple - 7/25/13 at 9:51am
post #5 of 5
Try here - http://www.cmple.com/c-218-tv-brackets.aspx. Many options available. You can also opt for the ceiling mounts unless it does not mar the look of your studio. But as you mentioned you want to use it while lying down on the bed, I do not think it should be a problem. Ceiling mounts are better if you are single and need to watch TV lying down on you bed. Good for your neck.
  Back to Forum: Portable A/V
