AVS › AVS Forum › Audio › DIY Speakers and Subs › What is the ideal router bit size for a roundover
What is the ideal router bit size for a roundover - Page 2
post #31 of 38
Originally Posted by JWagstaff View Post
What bit should I get from the MLCS website that would just be used to cut out driver holes and countersink them in a baffle? or what 2 bits?
1/4 spiral upcut
#5157 or #5146
post #32 of 38
I use a Jasper jig and a full carbide 1/4", 1/4" shank upspiral. My last build though, I cut my woofer recess by first going 0.25" deep all the way around with the upspiral bit and then changed to a 3/4", 1/2" shank straight plunge cut bit (adjusting the Jasper jig to the bit size) and mowed through the rest of it in about 60 seconds. Baffle done. The straight bit is a real go-to workhorse bit in my box-o-bits. smile.gif
post #33 of 38
Originally Posted by Gorilla83 View Post
I have at least 15 of the MLCS bits so far - of the 10 or so I've used, they haven't let me down.
I just tried their 1 1/2: radius bit for the 1st time; it also worked well, in a table mounted router and lowish speed.
It's so big I couldn't use an onsert ring, and makes quite the whirring sound.
Originally Posted by Bill Fitzmaurice View Post
3/8" is the standard for commercial corner protectors. Where edge diffraction is concerned less than about an inch and a half radius doesn't do much, if anything.
Isn't that overly general?
Wouldn't a smaller radius do for a tweeter what a larger radius would for a mid/woofer?
post #34 of 38
I wish there was a bit set with a 3/4" roundover.
There is. Whiteside Machine. 1/4, 3/8, 1/2, &3/4 about $95
post #35 of 38
Not sure how well you guys can see this, but it's a comparison showing the effects on a "typical" TM sized speaker. 8" x 16" baffle with a 1" tweeter centered 4" from the top.
From 0 radius to 1.25" radius in 1/4" increments
Note that the very large roundovers start to change the effects below 3 khz, which is where the crossover is typically found. If the speaker was designed with little or no edge treatment you actually could make things worse using a huge roundover, depending on the design.
post #36 of 38
Here ya go free shipping but don't know about Canada
http://www.hartvilletool.com/product/3323/roundover-router-bits
post #37 of 38
I meant one with a bunch of general bits. Like MLCS 15 piece that's only 40 bucks but it comes with 3/8" roundover.
post #38 of 38
Agreed Jay. It does depend on the design. One can see the amplitude rise as the radius changes and also when the driver directivity changes. That's a good simulation you've provided, it also helps to see this relationship to have save overlay "on" at zero radius. wink.gif
-Nate
