AVS › AVS Forum › Audio › Speakers › Jurassic Park on Paradigm Studio 100 :)
post #1 of 26
Hey guys ..
Having the amazing Paradigm studio 100's running on an old Yamaha Rxv-2500 120w*7 receiver , everything was running exceptionally great on most movie tracks I throw to this combo ..
Finally , I tried the Jurassic park Trilogy (DTS mastered) on these , with every single part on the movies was pretty good except on these Dinosaur's roaring scenes .. I feel like the sound gets disturbed and somewhat significantly depressed and compressed ..
What's going on ? is this a sign for adding a power amp to my Studios or what ? cool.gif
Edited by Dayter - 6/12/13 at 7:34am
Gear mentioned in this thread:
post #2 of 26
How far away are you seated from the speakers and how loud do you listen? 0db, -10db, -20db?
post #3 of 26
Yep, sounds like distortion is the problem. In other words, hitting the speakers or amps limits.
post #4 of 26
The studios if I recall are quite power hungry.. I would imagine it's time to add an amp to them not to mention I'll bet they will sound worlds better.
There is something to be said about the sound comming from a dedicated amplifier over a standard AVR IMO
post #5 of 26
Thanks guys ..
I usually listen at a level between -20 to -10 db according to the source , at 3 meters apart , which is quite loud enough to shake the walls , and is pretty impressive enough for most movies i watched like (Fast five , dark knight , saving private ryan , avatar , gladiator , ... etc. ) without any distortion and with great dynamic range and clarity ..
I felt these levels of distortion or compression just with movies like (King Kong , Jurassic park ) at the scenes where there is roaring from the dinosaur or the gorilla ..
What ? are these roaring sounds reaching transient power peak levels which my old Yammie isn't capable of producing calmly and clearly .. ??
post #6 of 26
Originally Posted by Dayter View Post
Thanks guys ..
Yep, it definetely sounds like it!...time to invest in a power amp. One of the best investments I made when I ran passive speakers. Check out Emotiva power amps, they are good quality and reasonably priced! smile.gif
post #7 of 26
thanks a lot ..
Seems i'm gonna invest too .. what about Outlaw amps ?
and i wonder why these sounds especially are pretty demanding for the speakers ? ! smile.gif
post #8 of 26
They are 8 ohm speakers and really can't take gobs of power so I am not sure more power is the answer, especially at -10MV or less. Try another set of speakers and see if it sounds the same, it could be the recording maybe? I have played with two different sets of Paradigms and both could not play as loud as the specs say, they compressed about 10 dBs lower than max and trying to push them just raised the distortion. These speakers were powered with 400 watt amps and the dealer told him he needed more power and guess what, they had exactly what he needed!
post #9 of 26
I don't think you're stressing the amp or speakers listening at -10.
post #10 of 26
I don't have the studio 100's but I do have the Studio 60's and I don't think I've experienced what you describe. I used to own a B&K 507 and now I own the Pioneer Elite SC67, which in some ways seems to sound better to me than the B&K did. I'll have to watch those DVD's again and see if I noitice what you describe. Initiially I'm leaning towards your power source being the issue and not the speakers. Lots of headroom with the Studio 100's.
post #11 of 26
Are you running them full range or crossed over to a sub?
post #12 of 26
You could also be having cancellation. Get a sub.
post #13 of 26
No , I'm using them full range without a sub yet ..
post #14 of 26
As the last 2 posters said, what you need is a sub. The receiver is not your problem.
post #15 of 26
I have Studio 100s and a rxa3010. Bought an Emotiva xpa-2 and have noticed a nice difference in overall sound. Don't know if that would help in your case.
post #16 of 26
http://en.wikipedia.org/wiki/Phase_cancellation#Multiple_beams
post #17 of 26
Wow do people really listen at -10 and 0db? That's crazy loud. Would u call that blowing speaker range? When I really wanna turn things up ill crank a movie to -17 but rarely get past that. -15 when I'm jamming music.
post #18 of 26
Well it is something that is hard to tell which is the exact issue. When you run the power hungry Studio 100s as full range, that can definitely put a strain on a receiver, especially if you listen to them loud. The second issue is as good as the Studio100s are at bass, they are not nearly as good as a sub.
post #19 of 26
I think most people here watch movies at -10. There's no range where speakers blow up. It all depends on what they can handle.
post #20 of 26
So would -10 be a safe limit then? Just wondering for demos. I.don't have an spl meter yet but will soon. Sorry to get off topic btw
post #21 of 26
Do you mean "-10" on your AVR? That doesn't mean anything unless your speaker/AVR combo has been calibrated; and even then we'd need to know what it was calibrated too (THX theater? THX home? Something else)?
post #22 of 26
Ahhh being a noob IV only calibrated using yapo but I would love to get an spl meter and tweek it even more. I really should look into things like what u recommended. Where would I start
post #23 of 26
Ypao should level match all speakers to the same SPL so 0db would be reference.
post #24 of 26
0 on my reciever in the exact location the yapo mic was when it was Calibrated ? Hmmm learned something new today ill have to thumbs up ya lol:)
post #25 of 26
That doesn't make 0 any particular reference. That just makes all the speakers the same level at a given listening position. It's a good idea, but "reference" usually refers to one of the two THX standards.
Generally: auto-calibration simply does +db / -db relative to get consistency. I have never seen auto-calibration put all speakers (for example) +6db to get 0 to be reference.
post #26 of 26
My Harman Kardon from this year (not my current reciever, bought an integra instead)
Level matched every speaker in the listening positon to 85DB.. I was actually quite impressed.
  Back to Forum: Speakers
