AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Which TV is right for me?
post #1 of 7
Hello everyone,
I've been lurking on the forums here for quite a while now and decided to take the plunge and post my dilemma.
Basically, I need a new TV. I've always gone with Plasma in the past and would like to continue to do so. I mainly stream my movies or watch BR movies - very little actual TV and no cable. I do game a lot though, I'd say 50% of my TV time is gaming these days.
So I'm looking for a TV that essentially ticks the following boxes:
Plasma
Min Size 50" Max Size 65"
3D
I'd like to keep the price below $2,500 if possible.
I was considering the Panasonic ST60 but the input lag issue has made me take a very long pause on that one. I have no idea about the offerings from Samsung or LG. I've looked online and through these forums but have not really been able to come up with a short list that I'm happy with. If worst came to worst I'd be open to the idea of a LCD/LED screen but would prefer to stay with Plasma if at all possible.
Does anyone have any thoughts or recommendations?
post #2 of 7
Get the VT60. Has good input lag and great Picture
post #3 of 7
Thanks for the input. I was looking at the VT60 series but the price is significantly higher than what I was looking to pay (at least here in Canada).
post #4 of 7
Don't know where in Canada you are, but if there is a Visions Electronics there, you can get the 55vt60 under you price with some haggling.
post #5 of 7
Hi RodK, thanks for the reply. I'm in Halifax, I can see the Visions site has the 55VT60 on sale at $2,698.00. It cannot hurt for me to call and see what else they can do though.
post #6 of 7
If you can't afford the VT and are concerned with the input lag on the ST60 than checkout the S60, has input lag of 34.1 ms I believe and has really good pic quality. The only thing it's not 3D and is super cheap. Or better yet if you can find a GT50 , it has everything you need and has even better input lag of 30ms input lag and has 3D and bells and whistles. I don't know where in Canada you are but my neighbourhood Visions electronics has a GT50 60" for just under 2 grand. Just a suggestion.
post #7 of 7
Ah I'd not thought about the GT50 - sounds like a very good option though, thanks very much.
