AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › KV-34HS420 Trinitron
post #1 of 4
My Sony Trinitron is not working. It comes on for a few seconds and then promptly shuts off. There is a flashing red light on the front of the TV (Stand by/timer) that is flashing 6 times intermittently. Any ideas how to fix.
Thanks for you help.
post #2 of 4
hello i noticed nobody has replied to your easy question there are TONS of posts on this sony problem it is probably two IC that need replaced google my sony flashes 6 times .......study the results!pretty easy repair and almost always is the problem!!!
post #3 of 4
I decided to trash the unit since it was going to cost me $150 to repair and I didn't feel I had expertise to fix it myself.
We ended up getting a FREE 32HS Trinitron.
Best,
Preston
post #4 of 4
cool preston ! the gods are smiling on you! feed it a nice HD signal and it should impress! have agreat day! Brian
