post #1 of 1
I have a basement room that is 17'X25' with a Trey Ceiling that is 8' to trey and a little over 9'. I have never had a projector so I really don't know what I am doing. I have enclosed some pics of my room and equipment. Like others on here, I thought I would only need a power receptacle and an HDMI routed to the projector. Also I was just using regular speaker wire that is 12 awg. My equipment that I have now is and Harmon / Kardon AVR2600, Jamo 5.0 entry level and a 10year old 100watt self powered JBL subwoofer. Also, Dish Network, Apple TV, and an Xbox that I have used maybe 5 times. Further, I just bought a refurbished LG BluRay player, my first one.
Because I have a trey ceiling I am running into set up issues in many areas. My seating area before the two metal support polls is 11' to 17'4" with the future plan of a bar behind that with some stools for extra seating during football games. At first I am starting with just 3 theater recliners and then if I have room, 3 more elevated behind and then the bar behind that. Lastly the fridge and a small kitchen area on the back wall. I have never really seen a home theater projector setup in person, so I am flying blind.
Questions that I have are:
*Should I use the DataCom or something else for projector in ceiling?
http://www.amazon.com/DataComm-45-0021-WH-Recessed-Voltage-Cable/dp/B001C4EAL8/ref=sr_1_3?ie=UTF8&qid=1371219208&sr=8-3&keywords=home+theater+plate+datacom
*Which of these would work best for that size room, for watching college football, hockey and movies? I guess buying a projector ahead of finishing helps in determining where to a connection in the ceiling.
Epson PowerLite Home Cinema 8350
Mitsubishi HC4000
BenQ W1070
ViewSonic Pro 8300
Any other suggestions?
*What screen would be a good match? size? color? gain? I am pretty good at DIY so that is not out of the question if decent quality can truly there in a DIY screen.
*Is this sufficient behind the receiver? What works best for the receiver and for speakers if I go with all wall mounted?
http://www.amazon.com/Vanco-HTWP72BW-Whole-House-Theater/dp/B001702I1Q/ref=sr_1_1?ie=UTF8&qid=1371219372&sr=8-1&keywords=home+theater+plate
*Suggestions some decent in wall speakers for my the side and rear speakers? Or should I try to avoid that?
*The AVR 2600 allows for a 7.1 system, but I don't know if I should place the rears all the way on the back wall?
*Have you found it a pain your equipment all put in a utility closet, I have that option under the stairs?
*What have you found to be good sound deadening insulation to put in the ceilings and walls under the sheetrock?
I am going to attach some pictures with the hopes that I might get some suggestions on what to do and buy next.
Thanks in advance,
[/ATTACHMENT]
Edited by Ezonebroker - 6/14/13 at 7:31am
