AVS › AVS Forum › Video Components › Video Processors › algolith dragonfly remote help!!!!
post #1 of 4
I just got a used Algolith Dragonfly and it did not come with a remote, I believe it is set to the wrong video output as I cannot see anything on the set from it.. I found a place to download the manual, it states that you have to hit the format button on the remote to change the video output resolutions.. but I have no remote! I downloaded from the Logitech site the dragonfly, however the format button does nothing, the unit has a blue light on the front that flickers when you press any buttons, the format button does not make the light flicker..
I need to find this remote, or find someone with this processor that would let me borrow their remote to program mine.. I would gladly pay for the use of it.. or if anyone knows anywhere I can buy this remote, please direct me there.... I found NOTHING on line with my hunt so far.. except the manual which I printed out..
PLEASE HELP!
post #2 of 4
Can't help you directly, but I think that the Dragonfly uses the same remote as the Mosquito HDMI units. Should make it much easier to find somebody with a running unit.
post #3 of 4
I am hoping that is the case.... I have someone who I sold the Mosquito HDMI to who should have the remote.. he is still digging around for it.
post #4 of 4
Is anyone out there using this in their setup?
  Back to Forum: Video Processors
