AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Wiring a Hardwire Box for Surface Lighting.
post #1 of 5
Would anyone know if this hardwire box: http://www.menards.com/main/lighting-fans/indoor-lights/accent-lights/hardwire-junction-box-black/p-1656071-c-6349.htm has a load, line, and neutral wire for wiring to an Insteon light switch? I tried going to the manufacturers website and it doesn't exist.
post #2 of 5
As far as I can tell that's just a surface mount junction box - which means it doesn't have any wires in it. You provide the wires which would be in it. It basically just looks like a rocker on/off switch. Not sure what/where this would be used.
post #3 of 5
It actually has a black and white wire coming from it with a green wire that comes with the package, sorry I should have mentioned that in my original post. I just have no clue when it comes to this stuff what that means.
post #4 of 5
well, from your link:
1. Consult a licensed electrician if you are not sure about the installation!!!
but yeah, it converts an in the wall wire to the little 3 wire plug(s) used by some under counter lights.
This might help: http://www.menards.com/main/store/20090519001/items/media/Electrical/american_lighting_patriot/Install_Instruct/Hardwire_Junction_Box_instructions_warranty.pdf
post #5 of 5
If that box is a surface mount switched 2-wire to standard Edison plug adapter, then it is fine.
You would use a plug-in type Insteon product with it.
The LINE and NEUTRAL (along with ground) come out of the wall, into that box. An electrical load are the lights themselves.
So the hot wire (black) coming out of the wall is 'line'
The neutral wire (white) coming out of the wall is there.
The load wire is the black wire which runs to your actual lights. That is the one which gets dimmed.
It all depends on what you are trying to dim and which Insteon piece you are intending to utilize with this.
  Back to Forum: Home A/V Distribution
