AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › acer h 5360 projector screen flickers blue
post #1 of 3
my acer h5360 every few minutes the screen will flicker blue in the middle of a movie. i just put a new bulb into it and it still does it. anyone know whats up with it or how to fix it thanks
post #2 of 3
Does it do this with all video sources or just the one for movies? Not enough info for anyone to diagnose
post #3 of 3
DLPs flash colors sometimes as a result of the colorwheel sensor being dusty. You could carefully try to blow out/vacuum dust using clean, dry compressed air. did you replace the bulb to "fix" the color flashes.. or was it doing it already?
here's a different model but same basic idea http://www.instructables.com/id/Disassemble-and-Clean-an-Optoma-HD70-Projector/
google has 100s of hits on dlp flashing blue
