AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Jolida FX10 integrated amp questions
post #1 of 2
1. Is it good sounding?
2. Can the stupid blue LED be turned off?
3. Will the actual tubes glow 'naturally' amber?
I'm thinking of buying this amp partially for aesthetic reason but if it doesn't sound decent, what's the point? Might as well just buy a bunch of amber bulbs biggrin.gif
post #2 of 2
Do not EVER buy anything from Jolida. Two capacitors went bad and they kept my amp for over TWO MONTHS and charged me almost $300 to fix it. NO APOLOGY whatsoever except to tell me their "systems weren't the best". $300 for two capacitors. Two months. No contact from them. EVER.
Their stuff is just rebranded Chinese crap anyway.
