AVS › AVS Forum › Video Components › Home Theater Computers › Who is using WTV Metarenamer?
post #1 of 9
Is anyone here using wtv metarenamer (http://wtvmetarenamer.codeplex.com/)? It is a program that uses the metadata in the wtv file to rename it with season and episode numbers. I have it setup to rename the shows on my WHS and move them into a folder that mymovies monitors. It works great for some shows but there are a number that are not recognized. Some of the series include Archer, Masterchef, the voice and a couple others. Does anyone using this have tips on tweaking the xml files to get better results?
post #2 of 9
What does your series.xml look like?
post #3 of 9
Here is my xml file.
Code:
<?xml version="1.0" encoding="UTF-8"?>
<config>
   <default_language></default_language>
   <xml_cache></xml_cache>
   <recordings>F:\ServerFolders\Recorded TV</recordings>
   <accept_single_bme>True</accept_single_bme>
   <move_to>N:\ServerFolders\ArchivedTV</move_to>
   <move_to_single_folder></move_to_single_folder>
   <season_folder_name></season_folder_name>
   <season_number_format></season_number_format>
   <episode_name_format></episode_name_format>
   <create_series_folder_if_missing></create_series_folder_if_missing>
   <delete_if_dest_exists>True</delete_if_dest_exists>
   <min_age></min_age>
   <change_char from="&amp;" to="and" />
   <change_char from="?" to="" />
   <change_char from="/\" to="-" />
   <change_char from=":" to="," />
   <ignore_series></ignore_series>
   <only_series></only_series>
   <create_undo_logs></create_undo_logs>
   <create_processing_logs></create_processing_logs>
   <move_unmatched_series></move_unmatched_series>
   <move_unmatched_episodes></move_unmatched_episodes>
   <move_duplicate_episodes></move_duplicate_episodes>
   <move_ignored_series></move_ignored_series>
   <attribute_title></attribute_title>
   <attribute_date_created></attribute_date_created>
   <attribute_subtitle></attribute_subtitle>
   <attribute_program_description></attribute_program_description>
   <attribute_recording_time></attribute_recording_time>
   <attribute_broadcast_date></attribute_broadcast_date>
   <convert_to_dvrms></convert_to_dvrms>
   <delete_wtv_after_conversion></delete_wtv_after_conversion>
   <move_wtv_after_conversion></move_wtv_after_conversion>
</config>
post #4 of 9
Thats your configuration file. You might try it with accept_single_bme False
Look again. You should have an XML subfolder. In there should be serieslist.xml. You can edit this one to get your shows right.
post #5 of 9
I thought that all the configuration was done in the wtv-metarenamer.xml file, which is what I posted.
post #6 of 9
Bump
post #7 of 9
Did you check your SeriesList.xml file?
post #8 of 9
I checked the series.xml and added match broadcast date flags to a couple series and that cleaned up a few more. What about a series that is not showing up in the series.xml? Specifically The Voice?
post #9 of 9
Try adding them.
Look them up on tvdb.com
The Voice
series ID 247824
