AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Where to set crossover on Yamaha HTiB (YHT-399UBL)?
post #1 of 6
I just got this HTiB, which has five small satellites and an active subwoofer. It doesn't have a crossover setting on the sub itself but in the A/V Receiver menu there is a crossover setting with the following choices: 40, 60, 80, 100, 110, 120, 160, 200Hz. (80Hz is default). Is there a particular setting to target or should I simply turn it up to 200Hz, since the other speakers are small (including the fronts)? If it matters, the auto-cal sets it to 120Hz in 8 ohms mode and 80Hz in 6 ohms mode.
post #2 of 6
I think the ypao setting of 120hz sounds about right. Do you know the specs on the speakers (freq. response)?
post #3 of 6
As far as the specs from Yamaha go:
SW: 28Hz to 200Hz
Satellites: 90Hz to 50KHz
Crossover Frequency: 4000 Hz
post #4 of 6
And which x-over setting sounds best to you?
post #5 of 6
between 120Hz, 160Hz, and 200Hz, 120Hz sounds best
I used the final battle scene in the Avengers BD for the comparison. It has multi-channel DTS-HD MA audio.
post #6 of 6
Well, you have it then. You and ypao both agree.
