AVS › AVS Forum › Audio › Speakers › Looking for help with speaker setup for movies/TV in large family room
post #1 of 4
Hey everyone,
Thank you in advance for sharing your time and expertise. I'm going to try to be as informative and concise as possible. Let me know if I miss something.
The situation:
  • My family room is 27' x 23' x 9' (~5500 cu. ft.) and is built over the garage (pictures at bottom).
  • We're considering placing a 60" TV over the fireplace, but the options for speaker placement seem very limited (see pictures).
  • The wife and I would use the room for movies (30%) and TV (70%) and are looking for at least a 5.1 setup (anything more is a nice-to-have).
  • The currently proposed setup (below) would run around $1600 for LCR and two rears; however, I could probably double that budget, if needed. I will probably need to upgrade my sub, but not sure what I need or what I should expect for price yet.
  • I'm not beholden to any speaker company; although, I've used Energy speakers for several years and really like their sound.
  • I currently own a Denon AVR-1910 for a receiver.
My current thoughts:
The best solution I've found for the front is 3x Martin Logan SLM for LCR, much like in this picture (left):
Because the wall behind the seating angles inward, the space for rear speakers seems a little tricky and I'm looking at doing 2x ML-65's for in-wall behind a sectional sofa.
For subwoofer, I currently have an Energy ESW-V8. I love how much "oomph" it puts out for its size, but I'm doubting it will be sufficient for the family room.
Questions:
  • Does anyone know if these SLMs can put out enough sound for the room size? Or are there other options I should consider?
  • Will the ML-65's sufficiently match the SLMs or will it sound awkward? Once again, are there other options I should consider?
  • What qualities (e.g. size, wattage, etc.) should I be looking for in a subwoofer? Any recommendations?
Thank you in advance for your help.
Here's the promised pictures of the family room:
Picture taken from the back-left corner of the room. I'm using the chair as a placeholder for a sectional couch.
Picture taken from the back-right corner of the room.
Picture taken while sitting in the placeholder chair.
A closer look at the area around the fireplace.
post #2 of 4
Originally Posted by jklick View Post
Hey everyone,
The situation:
Questions:
Hi Jklick:
Have you considered placing the television in front of the big window in this room? That location would give you more flexibility for speaker placement. You have a big room, and I don't think the SLM speakers would give you the performance you need for this space. Floorstanding speakers would do a better job, and possibly 2 12 inch subs would be my suggestion. I'd also suggest going larger than 60 inches based on your seating distance - you're limited in screen size if you mount the panel above the fireplace. That is a beautiful room, by the way. Fireplace mounted sets look great in interior design magazines, but ideally, the television should be at eye level. Just my 2 cents.
post #3 of 4
post #4 of 4
The current distance between the seating and fireplace offsets the eye-level problems that you bring up. However, you're also right that the distance is too far for a 60" display. I went to a local AV place this afternoon and not only did I feel drawn to 65" displays, but the ideal seating for them was much closer than I'm currently designing for. That being said, if I moved my sofa a whole bunch closer, people would be hurting their necks.
It's not a bad idea to put a TV (heck, a much larger one) on a stand in front of the window. Honestly, I might die a little inside because it's a pretty window that we'd be covering up, but I'd like to keep my options open still - beggars can't be choosers. Actually, I just presented this idea to the Mrs. and she vetoed putting a TV in front of the window. However, she wouldn't be opposed to a projector screen that comes down from the ceiling. The only problem with that is there are a lot of windows, so I would need some light-blocking blinds or shades of some sort.
Thank you for validating the SLMs will not work for the room size - I had my doubts. If I decide to do a projector screen in front of the big window, my number of options for speakers are going to put me in analysis paralysis for a couple more weeks. smile.gif
FYI: I tried out the B&W CM5's while at the AV store and they were amazing. In fact, when I played them just by themselves (with a subwoofer), it didn't sound like a center channel was missing. This was important to me because the center channel placement is the biggest headache for me if I persist in trying to do a fireplace setup. I could just place the CM5's on the bookshelf and be done with it.
It looks like my speaker project might be put on hold until I figure out where to put the display. However, I'm open to recommendations for speakers if I go the projector route. My wife seems interested in investigating in-wall and in-ceiling, whereas I'm not opposed to tower speakers.
  Back to Forum: Speakers
