AVS › AVS Forum › News Forum › Great Found Deals › Energy RC-Micro 5.1 $249 at amazon
post #1 of 8
http://www.amazon.com/Energy-RC-Micro-Surround-Speaker-System/dp/B001RQ2CXO/ref=br_lf_m_1001154591_1_1_img?ie=UTF8&s=electronics&pf_rd_p=1567836562&pf_rd_s=center-2&pf_rd_t=1401&pf_rd_i=1001154591&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0D57RDDPGP8WX2FBTFAG
post #2 of 8
How do these compare to the Energy Take Classic?
post #3 of 8
Build quality better on the micros but more frequency range on the takes - they would be better with a budget subwoofer.
post #4 of 8
Paired with polk psw505 subwoofer which would be a better option?
post #5 of 8
I've listened to both. Get the take 5. Has better range. Micros are way too small, and need a sub that can cover atleast from 120hz down onwards. Take 5, can easily blend with subs from 80hz on.
post #6 of 8
I don't think the Takes go down to 80hz. The ones I had sure didn't.
post #7 of 8
Correct. The center channel goes down to 110Hz, the satellites to 115Hz. I personally set the XO at 120Hz.
post #8 of 8
Agreed, I have both the Take and the Micros - I much prefer the sound of the Takes when both are paired with the same sub.
  Back to Forum: Great Found Deals
