AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Possible solution for protecting outdoor screens?
post #1 of 4
Now I don't have an outdoor screen but reading through the forums I do see that a lot of people have issues with protecting their outdoor screen. I came across the pretty awesome stuff that could possibly help with that! The guy in the video on this page says it has a slight frosty finish so I don't know what it would do to the reflected image, but if it works it has real potential!
http://www.homedepot.com/p/t/204216476?productId=204216476&storeId=10051&langId=-1&catalogId=10053#.UcDCr-c3tdw
post #2 of 4
I've read it has a semi-frosted finish, which means it will probably hot spot and ruin the picture. I may test it out though.
post #3 of 4
Let me know if you do!
post #4 of 4
If it is sprayed on in the Duster fashion, hot spotting would be greatly lessened. But as to the coating causing any blurring of the image because it has a frosty-like property, that is what would concern me most.
  Back to Forum: DIY Screen Section
