AVS › AVS Forum › Audio › Speakers › Klipsch Synergy S-10 Thoughts?
post #1 of 6
I've been looking for a pair of rear channel speakers for a few weeks (they're the last bit I need to finish my 5.1 setup.
Does anyone have any experience with the Klipsch Synergy S-10? Newegg just put them on sale for $120 which fits perfectly into my sub $200 for the pair budget.
I'm currently using A Polk CS2 center, Polk Monitor 60s as my front left and right and a BIC F12 subwoofer. I want to be sure that this will all fit together and sound nice.
ANY thoughts at all would be welcome, especially if you have any experience with these speakers.
post #2 of 6
Those Klipsch horn tweeters will be a little brighter than your Polks but otherwise it should be fine.
Have you also considered Polk OWM3's which can be wall mounted too?
http://www.amazon.com/electronics/dp/B0018QNYVM
post #3 of 6
The reason the Klipsch speakers were appealing ot me is that they aren't so one directional. I figured that would help for less than perfect speaker placement?
post #4 of 6
I'm not sure if these funciton similar to a bipole speaker or not.. Any insight?
post #5 of 6
How does the Klipsch S-10 pair match up to the RB-52 pair?
I have 12x19 room that will be used mostly for movies and video games.
I'll be running either the RB-52s or RF-52 for the front, likely the RW12D for subwoofer.
post #6 of 6
Has anyone compared S-10 and S-20?
  Back to Forum: Speakers
