AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays ›  Panasonic TC-P50S60 or LG 60pn6500 decision help please
post #1 of 4
OK.....I can get either of these TVs for the same price around $600.00.....Dedicated viewing/listening room with very little light with a viewing distance of about 11 to 12 feet.
Im giving a edge to the Panny for PQ and edge to LG size. Upgrading from a 46 LCD. 3D and Smart are of no consideration to me. Opinions or anything I have not taken into consideration? Thanks
post #2 of 4
10 inches is a lot. And upgrading from a 46, I think you will be amazed at how much bigger 14" is compared to only 4" upgrade. I originally went from a 55" to a 60" on a tv and barely could tell the difference. Honestly I'd go for the LG considering your viewing distance.
post #3 of 4
Thanks for your input....seems like 46 to 50 is such a lateral move....but don't want to buy into "bigger is better" and suffer considerable PQ
post #4 of 4
Also remember that the LG 6500 only has 2 HDMI inputs. May want to peek your head into the 6500 thread and see what peoples opinions are about it. It got decent reviews on amazon at least but people tend to get much more technical on here. Just weigh the pro's and con's of each wink.gif
