AVS › AVS Forum › Audio › Speakers › Jamo 5 Piece Home Theater Vs. Pioneer Andrew Jones
post #1 of 8
So as the title suggests I have decided on two speakers sets.
I have looked at both because they are in my budget range (400.00). The problem is, I do not live in an area with a best buy, so i cannot try these speakers out for myself. I need help from the AVS forums. Given a choice between these two speaker brands and sets, which one would you suggest i take and why? Do you think i should use both brands together? If you find a different set & brand that might be better within 400 dollar range, please let me know!!
I will link both sets below:
Jamo set: http://www.amazon.com/Jamo-Piece-Theater-Package-Black/dp/B003BPPAB0/ref=cm_cr_pr_pb_t
Pioneer Andrew Jones:
http://www.amazon.com/Pioneer-SP-C22-Designed-Channel-Speaker/dp/B008NCD2EI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1371723887&sr=1-2&keywords=pioneer+andrew+jones+speakers
post #2 of 8
I haven't heard the Jamo speakers, but the Pioneers have a huge following here and I think they sound great. There aren't many speakers than can beat them in terms of value. If you have a tigerdirect store near you, they also carry them.
I would go post in the Pioneer owner's thread and ask if anyone has heard that Jamo speaker set and if they can offer any comparisons.
post #3 of 8
I suggest that you get four of the Pioneer BS-22 speakers and the CS-22 center speaker.
You should read the article on the BS-22 in the current article of Stereophile magazine.
Amazon is currently selling the Pioneer BS-22 for the incredibly low price of $110 per pair, and the CS-22 for around $150.
The Jamo speakers are fair, but these Pioneer speakers are much much better-sounding speakers.
post #4 of 8
I have listened to the Jamo s426 and Pioneer speakers at my local Fry's. I think the Pioneers are clearly better speakers.
You should be able to get two FS52's, one C22 center and two BS22's for under $400.
The tease is that you can get the Jamo s426 in wenge color for $180. Then you can add a subwoofer for $220 or less.
http://www.amazon.com/Jamo-426-HCS-WENGE-5-Piece/dp/B003GGXGU6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1371742392&sr=1-1&keywords=Jamo+s426
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1371742491&sr=1-1&keywords=bic+subwoofer
post #5 of 8
Well it seems unanimous that people are in favor of the pioneers, so I think I will go with those! biggrin.gif
Thank you for your help! I know I can't try them out, but I have no reason to doubt you guys. smile.gif
post #6 of 8
Really? Cause current Amazon is selling the Bs-22 for 127.49.
post #7 of 8
You need to live by a Fry's Electronics. Friday's sale has the towers for $77 each and the bookshelf speakers for $77/pr.
http://www.frys.com/ads/page5
post #8 of 8
Check places like Best Buy, TigerDirect, Amazon, etc. Most of them will price match each other so you can get a good price and take it to Best Buy and go home with your new system.
  Back to Forum: Speakers
