AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Can't enter letters on Panasonic DMP-210
post #1 of 3
I'm trying to log into Netflix on my Panny DMP-210, but the remote will only let me enter numbers. For example, the "2" key also has "a, b, c" on it. On most keypads, to enter "b" you would should just hit the "2" key three times, but the only thing it will do is enter "2" three separate times. Couldn't find anything in the manual. What am I doing wrong? Thanks.
post #2 of 3
Found a post that says to hit 'OK' when you're in the window to enter your e-mail address. Should bring up a virtual keyboard. I'll give it a try.
post #3 of 3
Having the exact same problem. Hitting OK in the email box worked! Virtual keyboard popped up. thanks!
