AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Nvidia 3D Vision on a 2D Plasma? MAYBE! (85hz & 120hz) Refresh Rates - Works!!!
post #1 of 7
So I was able to make forced refresh rates of (70hz - 120hz) on my Panasonic Plasma with Custom EDID timings... Anything higher than (70-85hz) on Progressive formats caused screen waves and frequency shaking "distortion".
1920x1080i (Interlaced) @ 120hz
1280x720i (Interlaced) @ 120hz
1920x1080p (Progressive) @ 70-85Hz
1280x720p (Progressive) @ 70-85Hz
So now I wonder to myself something...
I wonder if the nVidia 3D vision Kit I am getting soon would work on this Plasma! smile.gif
http://www.nvidia.com/object/3d-vision-system-requirements.html
All nVidia says you need is a 120hz capable display + 3D Vision kit and glasses + nvidia GPU + PC
MAYBE! I just wonder If I could get Nvidia 3D vision to accept the 1080i,720i 120hz signal?
MAYBE! if it could just accept the beefier 70-85hz modes for 1080p,720p?! biggrin.gif
Honestly my Panasonic has great interlacing/interlacing tech performance... I couldn't really tell the difference between the 1080i 120hz and 1080p 85hz as far as picture quality goes.
Check this site out. LOTS of people are testing their TV capabilities with EDID edits and custom timings only to find hidden supported refresh rates! biggrin.gif
Any thoughts on this and if there is a way to make custom resolutions and timings for Nvidia 3D Vision?
post #2 of 7
This is very interesting. do you know what AMD's equivalent to this is? or is it only nvidea?
post #3 of 7
Not sure about Nvida. The TV is why I am capable of these modes. Plasmas are very fast and have great tech. I had no idea it could accept an input of 70hz 80hz and 120hz in interlaced/De-Interlaced modes
post #4 of 7
How were you changing the timings? I only saw Low and High in service menu. Was it editing the EDID clock itself?
post #5 of 7
Yeah Nvidia CUSTOM timing editor in the Control Panel. BE CAREFUL!
post #6 of 7
Somewhat related, have you guys heard about lightboost...http://www.blurbusters.com/zero-motion-blur/lightboost/
I am trying to research all things computers in the hopes of building one for the first time, and I happened upon it. Supposedly some people really like lightboost saying it is just like CRT of days past.
post #7 of 7
Jonathan what panel do you have? I am intrigued how you can push up to 85hz at native res, it implies Panasonic have increased the data path since 30 series. You might be able to push further with the Toastyx CRU utility which is brand agnostic as far as graphics cards. I know for a fact Panasonic has hidden 125hz drives modes because I had that working with my old graphic card
My current custom timings are
1536x864(120hz, 16:9 scaled)
1440x1080(100hz, 4:3 mapped)
Anything in the range of 48-125 is graciously accepted but only 50,60,100,120,125 modes appears to be 100% smooth as if they are defined modes
