post #1 of 1
I have a Samsung sound bar I used in conjunction with my old Samsung LED TV.
Today I got my UN55F7500 and am very excited to use it.
Here is the BIG issue. I set the TV to external speakers and have my SAMSUNG sound bar hooked up to digital audio out. Whenever I change the volume on the sound bar the TV picks up the signal and says "your TV is set to use external speakers. Please adjust the volume on the external speakers directly" even though that is what I'm doing!!!
The signal from the sound bar remote apparently is the same or similar to the new TV and it gives me that error every time I change audio levels.
How can I fix this? My sound bar is the Samsung HW-C450.
Thanks so much in advance!!!
