AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Can subwoofers cause hearing loss and Tinnitus
Can subwoofers cause hearing loss and Tinnitus - Page 2
post #31 of 36
Originally Posted by asere View Post
What you are saying the low frequency will most likely not cause damage but how about mid and upper bass?
The decibel level potential for damage closely resembles an equal loudness chart, as does 'A' weighting, and that's why 'A' weighting is used for exposure times.
post #32 of 36
Originally Posted by eljaycanuck View Post
Nope, in the same way that upper-lower class isn't the same as upper class - it's still just part of the lower class. wink.gif
The bass part of the spectrum is sub-divided and includes mid-bass and upper-bass. High frequencies are a different part of the spectrum. This diagram gives you a rough idea (scroll to the bottom of the pic to see the ranges).
I have a mild hearing loss around the 3k to 8k so that would be the high frequency right?
post #33 of 36
According to the diagram, that would be in the "high mids" to lower "high frequency" ranges.
post #34 of 36
That is strange mine usually hisses or hums but hardly rings and its not loud.
post #35 of 36
I don't get it. There's nothing strange about tinnitus that hisses or hums, or that isn't very loud, or that isn't in the same 3,000-8,000Hz range as your hearing loss.
Edited by eljaycanuck - 6/25/13 at 6:20pm
post #36 of 36
Well I heard that the severity depends on what frequency is damaged. I guess that's not so.
