AVS › AVS Forum › Audio › Speakers › New Speakers $300 budget
post #1 of 5
Helping my friend get new speakers.
Some notes though, we both have the same receiver or had it. It was the HT-RC360. I would recommend the Polk Monitor 70 but I'm hesitant to. I blew my tweeters twice, and I know he likes listening at loud volumes like I do. I hardly think the amplifier in the HT-RC360 will power these speakers. In fact, I know they won't because I blew my tweeters twice haha. They currently run off a Crown XLS1500 now and are never low on power.
Wondering, are there sensitive speakers that would do well on the HT-RC360, he has a subwoofer already by the way, or is there a good amp/speaker combo that he can get where he can upgrade the speakers later but still get something decent now.
I realize that the HT-RC360 doesn't have preouts, but is there an amplifier/speaker combo he could get where the amp would take speaker level inputs?
These are the questions I wanted to know before recommending him something. I would recommend a lower power requirement speaker but we tried the Polk Monitor 50s and blew those too. I just don't have much faith now in tower speakers, with my listening habits, unless I'm using an amplifier.
post #2 of 5
How big is his room?
Is he looking to just have a couple of stereo speakers or does he want to expand to surround sound someday?
Also, what does he listen to?
Any size/space/color considerations?
Does he live in a major metro area where there is a Fry's?
post #3 of 5
There aren't many speakers within that budget which will take the kind of abuse you give it. Your best bet is a pair of these BIC America FH-6ts. You could also look for used PA speaker like what DJs use.
post #4 of 5
Since you already have a subwoofer the DIY Karma-8 kit is a get high output speaker that is very sensitive and doesn't require huge sums of power.
http://www.diysoundgroup.com/waveguide-speaker-kits/karma-series-kits/karma8-kit.html
http://www.diysoundgroup.com/flat-packs-1/seos-flat-packs/eos-8-flat-pack.html
There is also the Cheap Thrill kit that uses a high output 12" woofer and compression horn tweeter and will play very loud.
http://www.diysoundgroup.com/waveguide-speaker-kits/bwaslo-15-kit.html
post #5 of 5
There is a Fry's near one of us and I go to his place so I wouldn't mind picking it up. No size/Color considerations prefer black and yes surroundsound some day.
Music mostly. We throw parties a lot and have similar listening habits. We blew 2 sets of speakers each because we didn't have enough power from the HT-RC360 to the speakers. So I need "sensitive" speakers right?
Oh, the room was 12 by 12.... So not that big and still it wasn't loud enough for us =/
Ok I'll look at those, I think I'm looking for "sensitive" speakers right? Speakers that get loud without that much power.
I'll look into DIY but for him it isn't as big as an option as it is for me. I love doing this, he might not.
Edited by tential - 6/22/13 at 11:10am
  Back to Forum: Speakers
