AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers
Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers - Page 28
post #811 of 1363
There is a sticker on the back of the panel that tells you the build month; September and later the fans have had the foam fix applied although no one knows on whether Panasonic installed quieter fans as well.
Best Regards
KvE
post #812 of 1363
Should be August and later actually, but it's still guesswork.
post #813 of 1363
I want to prevent getting a VT60 with a build date earlier than September. Does anyone who bought a VT60 remember whether the serial number (not build month) is shown on the outside of the box? The Best Buy warehouse claims there is no way to identify the serial number without opening the box and they won't do that before delivering it. Most electronics I have purchased have S/Ns on the outside of the box, so I am skeptical of the answer.
post #814 of 1363
jhersco,
The box with my 60VT60 had removable peel-off stickers with the serial number on them. There were three stickers one of which had been removed. When I asked the delivery person for the serial number before he took the unit off the truck, he simply tore off the remaining two stickers with the backing still on and handed them to me. Months before when I received my 65VT60 I did not ask and since then the box has been discarded.
Larry
post #815 of 1363
On the box, the S/N will be on a white sticker with an small orange sticker on it. It will be MK3xxx... The three numbers after the 3 indicate the day in the year the was manufactured. From that you can figure out which month it was.
post #816 of 1363
LarryinRI, p3Orion,
Thanks. I was fairly sure that the S/N would be there. I will try again with Best Buy to get this checked BEFORE they try to deliver to me.
post #817 of 1363
Best Regards
KvE
Wouldn't we be able to tell if Panasonic installed quieter fans from pre-August vs post-August photos? I know several people posted pictures of the back panel of pre-August TVs.
post #818 of 1363
There is no sticker with a month on it. Just a serial number. And the production origin. Czech.
But when I shine a light on the back I can see. Foam.... So that's a good thing.
I have a European model. And see several different serial numbers going by.
Starting with mk and fz.
post #819 of 1363
for the ZT is there a SN code on the box or just a sticker on the back of actual panel.
post #820 of 1363
On the North American tv's there's a S/N on the box and a sticker on the tv that has the S/N and month built. It's been that way for years.
post #821 of 1363
And the serial number pattern for ZT's... all I can seem to find is the MK3nnn... pattern for the VTs
post #822 of 1363
Serial pattern for the ZTs is MK3[ddd][nnnn] where [ddd] appears to be the Julian Day and [nnnn] is the panel number for that day.
post #823 of 1363
Originally Posted by vinnie97 View Post
That's the rumor going 'round. It's not inconceivable that they could be completely out of the consumer TV bidness by the time OLED hits its prime.
Yes I heard they are completely out of the TV business
post #824 of 1363
From what I have learned so far, until they can come up with an affordable OLED, they will be outsourcing panels on all their LCD's.
Ian
post #825 of 1363
Originally Posted by cwick View Post
Purchased in late November from Paul's TV, July build date. Fix on order 55VT60 also.
Are you sure you are seeing the fix foam and not the outside foam? With a July date I would expect you do not have the fix applied.
Tech coming out the 1st to apply the fix, 55VT60. Interesting, he said there was a recent tech advisory for VT and ZTs, to not try to move the display while the back is off. Evidently the panel can be easily damaged when the back is off. The back must be providing some support.
post #826 of 1363
Just had the fix done on my July build 65" vt60. Fan noise is gone! I also applied the washers per the suggestions from this thread. Life is good smile.gif
post #827 of 1363
Great! Thanks for letting us know how it turned out.
post #828 of 1363
Guys, just got my 60" VT60 from Amazon with a June 2013 build date :(  Although the set is incredible, this is before the supposed fix.
What should I be on the lookout for? Is this a problem that worsens with time? Also, does Panasonic just come to your house to install the foam? Thanks!
post #829 of 1363
"Is this a problem that worsens with time?"
No, it's immediately noticeable, and it's what you should be listening for (pulsating fan/air noise) that matters. wink.gif
"Also, does Panasonic just come to your house to install the foam?"
Yes.
post #830 of 1363
Since you are all owners of the Pana was it worth it even so 4K is here
post #831 of 1363
For me, yes, because native contrast ratios, black levels, accurate color are more important than pixels at producing an accurate picture.
I like 4K as a concept that may drive larger screen sizes though.
- Rich
post #832 of 1363
Kind of like asking a Ferrari owner if he's still happy with his choice now that the new Tesla is out. Apples.. Oranges. Different technologies. LCD is still LCD. Let's keep this topic to the plasmas at hand.
post #833 of 1363
4K is all hype right now. Almost every review states that the current plasma will likely out perform 4K for a while since all 4K sets will be LCD based for some time and thus have all the black level limitations of LCD. Also if you look at the various charts you have to sit within a few feet of a 4K set to see any of the resolution benefits, and then of course the big thing is there is no delivery of 4K content. I also find it odd that Netflix recently announced 4K content is coming, but really? Their current HD content is not even BD level so why send out 4K.
post #834 of 1363
Well ok, but 4K OLED IS THE FUTURE
post #835 of 1363
After disconnecting the fans and unscrewing them from the back plate simply remove the screws from the sheaths.
Insert the washers, one each, onto the screws and leave them at the head.
Then reinsert the screws into the sheaths and reaffix the fans to the back plate.
Reversing the sheaths for the fans may reduce vibrations from the fan motors but it will also change the airflow which might lead to increased heat.
Also I would not cover the air vents, there is a reason why they made those vents that large.
Good luck.
KvE
Just picked up the washers, going to ask the tech to add them Tueaday when he comes out to put the official foam fix on. Thanks for the info.
post #836 of 1363
So are flying cars and jet packs, some have claimed.
post #837 of 1363
Originally Posted by vinnie97 View PostSo are flying cars and jet packs, some have claimed.
Except you can buy OLED at Best Buy http://magnoliaav.com/promotions/lg-oled?utm_source=webpage&utm_medium=tout,+SLP,+email+&utm_campaign=LG+OLED
On Sale http://magnoliaav.com/products/tv-video/flat-panel-tvs/lg-1601055
and new models you will see at CES will show that OLED is the new TV generation that surpasses every thing out there.
post #838 of 1363
It's only a 55 inch @ 1920 x 1080p for.... wait for it... $8,500.
I don't understand why it needs to be curved either and that seems to be the selling point on BB page. First it was thinner TV's, then 3D and now curved???
The OLEDs may have a better picture down the road but at this point, all I see is the marketing departments creating hype around the tech to make people think they NEED it and they are living in the past without it. Not surprisingly this works on people with more money then sense.
Edited by Donat76 - 12/28/13 at 1:00pm
post #839 of 1363
Curved - it's the new Flat!
post #840 of 1363
Panasonic and Sony just virtually bailed on the tech. LG and Samsung are the only ones keeping it afloat in the marketplace, and they only shipped a thousand units this year, all curved and 55". The point at which these sets reach parity in pricing with today's panel's continually gets pushed back because of poor yields, as does the predicted number of shipped units. Would you please stop dragging this thread off-topic?
