AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Sony KV-30HS420 Red Screen, blacks red
post #1 of 3
I recently hooked up a new receiver to my system (Onkyo Tx-NR616). Now I could hook up all my components using HDMI and go directly to my old TV with HDMI. All was well until the night fell and I noticed a red tint in the blacks on the TV screen when going through my Sony BDP-S280 while streaming Netflix. If I go to any components home screen, the blacks are black but, as soon as I start watching anything I see the Red problem.
I unhooked everything, tried component out on the blu-ray, switched hdmi cables, etc. Still there. By accident, I looked up while everything was off but the TV and there it was, glowing a deep reddish black. I unhooked the HDMI cable to the TV...the glow remained.
Searching the net, I found this wonderful forum and went into the Service Mode of the Sony and changed RYR and RYB to 15 because I'd read of eliminating a "Red Push". It's still there.
Any ideas?
Rich
post #2 of 3
May not be the same thing but I had a similar problem with my Panny TV setup from one of my DVD recorders. Turns out it was the recorder putting out too strong a red tint AND color signal so I adjusted it in the recorder's menu (if I changed it in the TV's menu it would affect my other components which were fine as is).
I noticed you wrote that this occurred after hooking up a new AVR but it's not clear to me whether the AVR was still in place during your 'unhooking' tests. Some AVRs have their own internal set of picture settings...
post #3 of 3
Well, it has the red tint when everything is removed from the TV so, I'm assuming it's internal to the TV. I may have simply not noticed it until I hooked up the new Receiver and paid more attention!
