AVS › AVS Forum › Audio › Speakers › Best 2.1 CPU Speaker System Under $150???
Best 2.1 CPU Speaker System Under $150??? - Page 2
post #31 of 37
Stick with the Klipsch 2.1 system then. It is a good performer for the money, and should work well for you. I however would recommend getting a DAC (Digital to Analog Converter), to filter out interference from your PC. The Behringer UCA202 is a good choice, you plug it in via USB, and then connect it to your speakers via RCA. http://www.bhphotovideo.com/bnh/controller/home?O=&sku=422094&Q=&is=REG&A=details Also, www.monoprice.com is a great place to get cables and not have to overpay.
post #32 of 37
cel4145,
I have a polk PSW303 Sub i was trying to sell (its part of my old home theater)
can i use that sub with the Emotiva - airmotiv 4 for my home office?
and if so how would i connect everything?
post #33 of 37
Yes. It would work fine with the airmotivs. You would have to split the 2 channel output from your computer and run it to both the airmotivs and the sub.
post #34 of 37
hey guys thanks for all the input. i think ive decided to buy a pair of self powered speakers & add a sub later on rather then waste my money on a crappy 2.1 multimedia setup.
i came across a pair of Audioengine A5+ for $320 how do they compare to the Airmotiv 4's
audioengine also has the 8" sub i could always add down the rd
Edited by cjp3 - 6/25/13 at 5:06am
post #35 of 37
how are the Audioengine A5+ any good??
post #36 of 37
Yeah they are great speakers, can't go wrong either way.
post #37 of 37
think im gonna go with the audioengine 5+ for $330 cause they have a larger woofer which should be better for bass until i add a sub if i choose to & the 5+ speakers are prewired to add a sub.
  Back to Forum: Speakers
