AVS › AVS Forum › Audio › Speakers › Bookshelf speaker wall mounts
post #1 of 3
I've read threads regarding speaker mounts and followed links, however, all require some sort of drilling into the speaker cabinet. My speakers that i'd like to mount are Klipsch rb-61 II. They way 35lbs each. Klipsch decided that these were to be built with no on board mounting options.
I'd like to be able to mount them 7 feet high on the wall, but tilted down towards my work bench. I can't built an articulating shelf. Has anyone seen speaker mounts strong enough that will provide some tilting ability without drilling the cabinet?
post #2 of 3
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW/ref=sr_1_7?s=electronics&ie=UTF8&qid=1372083163&sr=1-7
post #3 of 3
Yes, I saw those but the reviews mentioned putting safety screws in. I would have to think that a 35lb speaker in that mount would need it?
  Back to Forum: Speakers
