AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Which Blu Ray players have excellent usb flash drive music support?
post #1 of 2
I have had three blu-ray players (panasonic, LG, LG), and playing music from a USB flash drive leaves a lot to be desired. It's like supporting music/files/folders/playlists/etc is an after thought with the most rudimentary of functionality.
I searched but there are no keywords that will lead to a concise post. So, if you have a Blu-ray player that you think has an excellent interface for playing music from attached usb drives (disk or flash), PLEASE add your 2 cents worth here!
Obeck
post #2 of 2
The Oppo 105 plays them superbly, and if you install the new firmware, it will play multi-channel DSD files, the highest resolution available (2.8224Mbits/sec!). It plays 2-track DSD files without the update. I only have a handful of files on a USB drive, so I can't speak to the way it deals with play lists. I do not, however, have any problem finding the files I want. I do understand that the 105 leaves something to be desired when it's connected to a network and it plays files from one's computer. You need CUE file to make sense out of the playlists in that case.
