AVS › AVS Forum › Display Devices › CRT Projectors › sony vph g70 question..... (from a newb) help?
post #1 of 2
nevermind.. solved
Edited by brodykmb - 6/25/13 at 12:47pm
post #2 of 2
Just come on over here :
WWW.curtpalme.com
There is a ton of info on the site and forum. Plus Curt can set you up with a moome card for HDMI.
BTW the DirecTV is gonna look at you like your crazy. Where you located maybe someone here or on Curts forum can assist you if you're local.
  Back to Forum: CRT Projectors
