AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Panasonic TC-32LX44 Sound Problems
post #1 of 3
My daughter was watching TV, hit an unknown button on the remote and now there is no sound. The picture and everything is great. I reset the set to the factory default and reprogrammed everything. I hit the mute button and see that is not the problem. I turned the volume up and down. I unplugged the set and plugged it back in and still no sound. I think I tried just about every button to no avail. If anyone can help me with this, I'd appreciate it greatly and send you some great karma lol.
Donnie P.
post #2 of 3
Couldn't find the owner's manual on the Panasonic site under that model number. Usually there's a setting to disable the set's speakers if you're going to be using it with a sound system. This will either be in the audio menu or the setup menu. If you still have the manual for the set it will only take a little digging to find it, if not explore all the settings under audio or setup.
post #3 of 3
Thank you for the reply. This is a closed matter now. Finally figured out she had muted the other remote. Too many remotes with too many buttons lol.
