AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 1613 Freeze Up
post #1 of 3
My 1613 (the second one, having swapped out the first) freezes regularly and needs to be unplugged and restarted. It's worse than my satellite box. Anyone having similar problems--and a fix?
post #2 of 3
Same issues with the first one? What sources? Have you tried resetting the microprocessor?
post #3 of 3
I think I'm not willing to give the unit the constant attention it seems to need. May look to swap it out for another brand.
