AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › Will my PC be good enough for the new GTX 760?
post #1 of 13
Over the past few months I have been looking to build a gaming PC/HTPC. The PC will be used to game on my 1080p projector. I was originally planning on buying and i5-3570k and a new z77 motherboard. But I was given a i5-2320 for free about a month ago. So I guess my question is will the i5-2320 with my current H77 motherboard be fine with the GTX 760? Thanks
post #2 of 13
Should be fine, it's a quad @ 3.0Ghz. It's not the best thing, and the 3570K would be better, but for now it should be fine. Just upgrade later.
post #3 of 13
You'll be CPU limited here and there, but it will work fine and will be a bit quicker than the cheaper GTX 660. There will be a noticeable difference in smoothness moving up to a newer i5 and you'll be able to hit 60fps a lot more reliably with a newer/faster i5, but it will still work just fine.
Rough numbers? You'll see a lot more common sustained dips in to the 45-50fps range with the 2320, whereas you would be able to hold a pretty stable 60fps with occasional 55fps dips at the same settings with a 3570/4670.
post #4 of 13
I thought this was going to be about your Power Supply ....
post #5 of 13
Thanks for the replys guys. I just cant see spending the money i don't have right now anyway on upgrading the cpu and mb for a little performance upgrade when my current CPU will work. Thanks
post #6 of 13
I have one other question for you guys. I have never bought a gaming card but I have been doing alot of reading. I am wondering which you guys would prefer.
MSI N760
Gigabyte windforce 3x
EVGA Superclocked ACX Cooling
post #7 of 13
Well according to techpowerup.com, they scored the cards like this:
MSI = 9.2
EVGA = 9.0
GIG= 9.1
Asus=9.1
No idea which versions as I didn't read any of the reviews. Just looked at the list of reviews.
post #8 of 13
A 760 is a 760. Pick the one that has two fans for cooling and is the cheapest.
post #9 of 13
I ordered the msi thanks
post #10 of 13
There is a nice review over at PC per. They also talk about the new card in podcast #257.
Edit: check out the sli benchmarks, there only 1080p but dang.
edit2: Toms has all the cards listed.
Edited by Amber Ale - 6/29/13 at 3:01am
post #11 of 13
so do we buy two 760's or one 770 or a 600 series with 4 gb of memory ?
seems like a new card comes out every three months. Glad I didn't put money down on that 680 I was looking at.
will this push the price of the 650 ti boost even lower, will amd have to lower their prices ?
post #12 of 13
Thanks I read all of that stuff. I was talking to my friend about my new card and he asked me if I wanted to sell my I5-2320 and MB to him. So I just bought a 3570k and an asrock extreme4 and it only cost me $150. I cant wait for everything to get here and up and running.
post #13 of 13
there is a 4gb version of this card out now.
sli benchmarks show two of these beating a single Titan card.
  Back to Forum: HTPC Gaming
