AVS › AVS Forum › A/V Control & Automation › Remote Control Area ›  Direct tv HD DVR34 Gennie ?
Direct tv HD DVR34 Gennie ? - Page 2
post #31 of 38
Edmund I got the DirecTV/TiVo Peanut Remote could you tell me the set up for the tv are their codes ?
post #32 of 38
I have told you the codes in the Genie are worthless, you said you have Stand Alone tivo, in its menu you will find the tv codes used by the THR22 remote. I haven't used the SA tivo, so I can't give you steps to navigate the menu to the tv codes.
post #33 of 38
Edmund I have the dvrhd34 Genie I got the DirecTV/TiVo Peanut Remote from weekness said it is the remote for the Direct tv dvrhd34 Genie ?
post #34 of 38
Here you mentioned you have standard TiVo:
http://www.satelliteguys.us/threads/313816-Direct-tv-HD-DVR-Gennie34-Remote?p=3202854#post3202854
Go into the standard TiVo menu, make your way to remote programming, under your tv brand, write down the codes, then try them in your weaknees Thr22 remote.
What is the brand of tv anyway?
To enter codes into the THR22 remote:
1. press and hold TiVo & TV power, until the light remains on
2. enter the tv code
post #35 of 38
Edmund I am a disabled personI have Direct tv HD DVR Gennie 34 got the DIRECTV TiVo Remote for THR22 or HR2X DVRs could you please tell what buttons work I will list the buttons could you tell me where on the recevier they are where do you put in the tv codes
post #36 of 38
I no longer have Directv, and never played with Genie receiver, can't help you there, sorry
post #37 of 38
Edmund do or know anyone who could tell me if DIRECTV Universal Remote RC71 or DIRECTV TiVo Remote for THR22 or HR2X DVRs go with the dvrHd genie
post #38 of 38
You have many threads over 4 different Forums sites, avs, dbstalk, sat guys, and directv own forums, i'm sure you're covered.
  Back to Forum: Remote Control Area
