AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Showroom "Calibrations"
Showroom "Calibrations" - Page 7
post #181 of 203
It should open with Microsoft Word. Or, you could use OpenOffice.
post #182 of 203
Hi Showroomcali. Could you please post calibration settings for the LGLA6210? I have a 55" and my blacks are horrid. Thanks.
post #183 of 203
Showroomcali any work on the Sammy 65F7100 have it on Standard
post #184 of 203
Originally Posted by showroomcali View Post
20 IRE is the 20 Point Grayscale. If you scroll down, you toggle the scale from 5-100. Cheers! Welcome to AVS smile.gif
Hi! Been trying the setting for 47LA6200 for my 60LA620. But I am stuck at White Balance settings.
I selected Colour Temperature as Warm1, Method as 20 Point Ire. U can have a look at the picture. After that, I'm lost.
post #185 of 203
Showrroomcali hasn't posted since 7/21/13. Until he starts posting again, if ever, you might want to pick up a commercial calibration disk such as Spears & Munsil, 2nd Edition, or the free AVS HD709 disk and adjust the basic settings yourself (color, contrast, brightness,sharpness, aspect, etc). You won't be calibrating your tv, for that you need meters and specialized software, but you can definitely improve pq and that may be all you need. Calibration settings don't always transfer well (actually rarely) from set to set because of component tolerances , panel type, and different viewing environments so you're best off to make accurate picture adjustments with a cal disk, learn how to properly calibrate yourself, or pay for a professional calibration.
post #186 of 203
Well said.smile.gif just bought this tv so I thought could just play around with it a little bit. Thanks!
post #187 of 203
Hello,
I am new to the forum and have a question.  I just bought an LG 32LN530B.  I got it at Walmart and paid $258 for it.  It is my first HD TV.  I have discovered that it has the capability to be professionally calibrated and am wondering if anyone has had it done on this model.  I think it would cost more than I paid for the unit to hire some one, but I would like to see the results if someone has had it done.  I would like to plug the numbers in just to see what it would look like as an experiment.
Overall, I am happy with the picture I get using the picture wizard, but the darks seem too dark and I can't seem to get them exactly where I want them.
Where can I get a copy of the free AVS HD709 disk?  That might help.
post #188 of 203
A professional calibration would probably start around $250. Use the Search feature to find the AVS HD709 files (it is in various formats). I don't have the link handy. You can burn it to a CD but will need a blu-ray player to play it, if memory serves me correctly.
post #189 of 203
I would love some settings for the Vizio M50 please!
post #190 of 203
^^^^ see post #185.
post #191 of 203
Hey, can you post some calibrations for the Sony KDL-55W900A? Greatly appreciated, thanks. (If he ever posts again).
post #192 of 203
Would appreciate settings for Sammy UN60FH6200
thanks
post #193 of 203
Showroomcali hasn't posted since 7/21/13. It appears he has other commitments. I would get a calibration disk and adjust your own settings so that they are specific to your exact model and viewing environment. Each tv has different component tolerances so what looks good on someone else's may look like crap on yours. A disk alone won't calibrate your set but all you may need is some fairly accurate adjustments instead of a full calibration which requires a light meter and specialized software.
post #194 of 203
Thanks...
post #195 of 203
showroom cali,
I just bought a vizio m701d-a3.  Were you ever able to find one to calibrate?
post #196 of 203
^^^^ see post #193.
post #197 of 203
Originally Posted by Otto Pylot View Post
^^^^ see post #193.
post #198 of 203
^^^^ well, with only 1 post to his name I'm willing to pass it off as newbiness wink.gif
post #199 of 203
Would greatly appreciate settings for Samsung UN55F7100.
Thank you!
post #200 of 203
^^^^ see post #193.
post #201 of 203
saw that post after I had already posted.
post #202 of 203
I have the same issue as wickedavs on my la6230
post #203 of 203
^^^^ see post #185.
