AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Need to confirm a Denon receiver audyssey mic? Thanks.
post #1 of 5
Have a Denon avr-4308ci receiver without calibration microphone. The original mic model should be dm-a505z, but I just saw somebody said the model dm-a405 is the upgrade replacement of a505z, it can be used for 4308ci.
Becasue of little info about it on the internet, not sure if dm-a405 is suitable or not. anybody here knows of it? I am thinking to buy one mic for the receiver.
Thank you very much.
post #2 of 5
http://www.newremotecontrol.com/denon/catalog_item.php?catnum=3210039004
http://usa.denon.com/US/Support/Pages/PartsDistributors.aspx
http://www.encompassparts.com/item/7515616/Denon/3210039004/Dm-a505zem_Avr4308ci
post #3 of 5
Thank you for your information. I checked on ebay, really expensive for the original dm-a505z. while dm-a405 has much reasonable prices.
I today contact local denon company, waiting for their reply, If buying one 505z model, i would get it from denon.
post #4 of 5
Encompass is a parts distributor for Denon.
post #5 of 5
Thank you all.
I got a dm-a505z new from my local denon distributor for a low price, very happy.
