AVS › AVS Forum › Video Components › Home Theater Computers › New Non HTPC build. i7-3970X centered build.
New Non HTPC build. i7-3970X centered build. - Page 2
post #31 of 42
OK, when I get some time this weekend.
On another topic, how would you go about physically connecting multiple monitors?
I want to do something similar to this below.
post #32 of 42
Just set them up as extensions in the control panel
post #33 of 42
I mean physically? How do you connect multiple panels to a limited amount of graphic cards?
post #34 of 42
they make 4 and 6 display port AMD cards. I assume 2 or 3 of them would work together.
Matrox also makes some splitters, but dont count on running 3d games effectively on that many cards.
post #35 of 42
Good to know. Thanks.
So the big question is, are there any bevel less Monitors coming out in the near future?
Or would I be better off getting a 4K TV like this?
Seiki http://www.amazon.com/Seiki-Digital-SE50UY04-50-Inch-120Hz/dp/B00BXF7I9M
post #36 of 42
Well if your going really big the higher resolution is nice. I might look for a smaller 4K PC oriented display
post #37 of 42
I ended up going with the 50" Seiki 4K. I will b interested as to how it looks. All reports so far say that it is pretty good. Just that when resolution is played at its max that you only get 30fs.
post #38 of 42
You need some pictures of this beast.
Normally I'd assume someone was trolling, but after knowing you I know better biggrin.gif
post #39 of 42
Maximum PC Magazine's latest issue has their Latest Dream Machine. Four overclocked GTX Titan Hydro Coppers and a 3840x2160 Asus PQ321 monitor.
post #40 of 42
Well the Titans arrived, well 2 of them for the time being. Stay tuned for pics.biggrin.gif
post #41 of 42
I just picked up one of these 29" 2.35:1 monitors for the desktop on sale. 2550x1080P and chainable display ports. Now wondering about
stacking a second one on top and running 2160x2550.
http://www.tomshardware.com/reviews/aoc-q2963pm-ultra-wide-review,3591.html
post #42 of 42
