AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Is this noise normal from a subwoofer?
Is this noise normal from a subwoofer? - Page 3
post #61 of 67
go with the best sub you can afford...thats the best piece of advice I can offer.
post #62 of 67
Ok, I just brought the PC13-ULTRA, now I just have to wait three weeks for it to arrive.
post #63 of 67
congrats! Im sure it will be a worthy upgrade!
post #64 of 67
That size room needed a good ported sub or multiple sealed to get the OP 's desired bass.
post #65 of 67
The OP's room is under 1500CF and it's sealed.
For the ULS to struggle in such a small room isn't something I'd expect from Hsu's best sealed sub.
post #66 of 67
Exactly...I was not even going to say anything since he apparently did not read the thread lol.
post #67 of 67
Yes I read the thread and then the end of my sentence was desired bass which may or may not of been having levels on the hot side.
I have had both sealed and ported and noticed that I always got more tactical feel out of the ported unit with same driver size your results may vary.
Even the mfg's will often try and sell two sealed units when the customer states he wants tactical feel in rooms of 1500cf even though his is just shy of that.
