AVS › AVS Forum › Video Components › Home Theater Computers › HTPC general setup
HTPC general setup
post #1 of 3
Haven't posted in a while...
When I had an injury, to make things more comfortable I got a good Lazyboy recliner and made a simple lap tray (just a veneered board) to hold mouse, keyboard and remotes. Has worked out great! Recliner arm/lap board just needs additional 1" high or so leveling up front so mouse doesn't slide around or off (I just use folded cotton material for now).
Have Klipsch RF-7 towers, custom 15" Tempest subwoofer and Odyssey Audio 150 wpc amp & preamp along with additional Oppo BluRay/high-end audio player. My PC is behind the 42" HDTV.
I got a HP Pavilion Elite top-of-line a few years back with 9 gigs RAM, GTX 260 decent video card that has held up well after a ton of use. Wireless keyboard & mouse are Logitech MK700/710 & M705.
Anyone else here have similar or ergonomic setups?
post #2 of 3
To be honest I used to have a very similar setup to you in the beginning of my HTPC use. There is nothing wrong with it but in my experience there are much more comfortable and better options. I had a similar setup and then upgraded to a lenovo remote:
http://www.amazon.com/Lenovo-Multimedia-Remote-Keyboard-N5901/dp/B0036VO67I
It worked ok but I was not loving it, the keys were harder to type than a standard keyboard. I saw a logitech k400 keyboard/mouse on sale for $5 so I jumped on it just because it was $5 not expecting much. This keyboard has been perfect for me, its relatively small but not as small as the lenovo (a good thing).
http://www.amazon.com/Logitech-Wireless-Keyboard-Multi-Touch-920-003070/dp/B005DKZTMG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1372613470&sr=1-1&keywords=k400
The k400 comfortably rests on your legs as its used but isnt too big either. I find the touchpad is awesome.
post #3 of 3
I use one remote and occasionally use a wireless mini keyboard but hardly ever as mine is basically remote controlled.
