AVS › AVS Forum › HDTV › HDTV Recorders › Direct tv tivo dvrhd34 "To record episode press R on your remote control" annoying pop up ?
post #1 of 13
This morning the record pop up appeared on CH 206 espn! and on other ESPN channels and others to I can not get rid of it do you know where I can get rid of it ?
post #2 of 13
I have read on some other boards that if you set up 5 or 6 series to record that goes away. It's a bug and they have to be series set to record and not single episodes. I don't have a 34 but some people that I really trust swear by this. good luck!
post #3 of 13
joed32 when you say up 5 or 6 series to record that goes could you please tell me the number of episode I record 1 episode per series and I can delete everything and pop up will go away
post #4 of 13
As I said, I don't have a 34 so I wouldn't know, experiment a little and find out how it works.
post #5 of 13
Does the DirecTV Tivo have an ATSC tuner for OTA antenna input?
post #6 of 13
I did set up series. did not change the default options on the DVR popup went away but if you need to have (always) at least 6 series links it is not realestic to do your DVR will keep recording shows and fill up my DVR any other way to make pop up go away
post #7 of 13
Change the options for each of those series to "Keep one at most" and it will not fill up your DVR. It's a bug and they will probably fix it eventually but for now there is only one way.
post #8 of 13
Could you set options for each of those 6 series links first run and no Repeats will it work?
post #9 of 13
I meant Could you set options for each of those 6 series links first run and Repeats will it work?
post #10 of 13
post #11 of 13
Try it!!!!
post #12 of 13
joed32 I meant Could you set options for each of those 6 series links first run and with NO Repeats will pop up go away will it work?
post #13 of 13
Tell me please the set options for first run and with NO Repeats on the Direct tv dvrhd34 in the series manager the order it is display on the Reciver ?
  Back to Forum: HDTV Recorders
