AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › pioneer kuro 151-fd picture cutting out with Sony ct260 sound bar
post #1 of 8
Hello everyone,
I was curious to see if anyone had a similar issue as mine at one point. I have my pioneer elite 151fd kuro hooked up through a Sony sound bar for video and sound. Has anyone ever experienced or knows of an issue that may cause the picture to cut out midstream while watching a bluray? This has happened
Twice and I'm beginning to think its an hdmi handshake issue. Could anyone please be so kind as to chime in if you know what the problem may be?
post #2 of 8
Bump
post #3 of 8
When the picture cuts out do you get a "no signal" or "HDMI1" (or similar) display? Or does the panel go totally black?
post #4 of 8
Thanks for the reply. When it has cut out (twice now) it will say hdmi 4.. Then it goes black. It sort of alternates back and forth. The other time it has cut out, the picture was a weird type of orange and rainbow colors. I immediately hooked up a source directly to the tv, and it was fine. That pointed to the Sony av sound bar being the issue; I'm just trying to be very sure. If anything happens to
This set id be heartbroken. I have less than 1000 hours on it
post #5 of 8
Ps.
I'm testing the ps3 with a direct connection to the input on the tv as we speak. If it exhibits the problem again I guess the culprit is the tv. I'm crossing my fingers
post #6 of 8
If it does go wrong with direct connection something is wrong with the main AV board in the unit, which is a replaceable part.
post #7 of 8
thanks Tom! Is this something I could do myself? And if so, where would be the cheapest place to get the part?
post #8 of 8
Yep. You can get it from used parts dealers like Shopjimmy or on eBay. Less than $150 for most parts; easily replaced by removing cover, disconnecting connections, unscrewing old board, screwing in new board, reconnecting everything, putting the cover on and testing it.
