AVS › AVS Forum › Audio › Audio theory, Setup and Chat › How to hook up 2 tvs to 1 stereo..help
post #1 of 4
Here's my problem:
I have 2 tvs that I would like to hook up to my stereo, but my stereo only has one rca audio input (red & white). Is it possible to hook up both tvs? What would I need?
post #2 of 4
Get a couple of RCA Y connectors. Just make sure you get the right ones: two female~one male. Not two male~one female.
post #3 of 4
I don't think you want to tie two sources to a single input w/o a switch.
Outputs from one device can normally be split to two different devices, but I think you will have problems if you try to tie two TV's to a single input on your AVR.
Brian
post #4 of 4
Originally Posted by SamsungBoy View Post
Here's my problem:
Audio only, right?
Just get one like this. There may be cheaper elsewhere.
Only one source will be able to play at a time.
