AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Best way to terminate RG59 into a faceplate?
post #1 of 2
I have a few rooms in my house with 2 Cat5e and 2 Cat6 with female keystone jacks ready to put into a gang.
However I've also run a single Coax RG59 to each location as well. It seems most people tell me to shy away from the F-connector and use BNC instead.
Would I buy a male BNC connector, then a female-female BNC keystone jack to do this? That's what it seems like even though my Cat5e cables could be directly terminated into the keystone without crimping or needing a male connector as well.
Gear mentioned in this thread:
post #2 of 2
Either will work as well for you. Either way, you terminate the cable with a plug and connect it to a barrel connector in the plate.
  Back to Forum: Tweaks and Do-It-Yourself
