AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Remote2 ap
Remote2 ap
post #1 of 3
I have the remote2 ap on my Iphone and can operate the display, but I can't figure out how to use the swipe and share. Is there a trick that I am missing? Searched the web didn't see a solution.
post #2 of 3
Isn't there a lan standaby or something in the eco mode? I thought I saw something like that before. Ideally it should be in some area with some power saving option or something.
post #3 of 3
Figured it out. You need to keep your finger on the item for a moment than the screen changes and you then can "swipe it" to play on your display. Its not just a simple swipe, its "hold and swipe".
