AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Can't post an avatar
post #1 of 6
Hi
Trying to add an avatar and i keep getting..."temporary error, please try again"....which i do but get the same error. Do i need a certain number of posts before i can do this?
thanks!
post #2 of 6
What are the specs of the image? Can you attach it to a post here?
post #3 of 6
No, it says "one moment" and stays like that...
post #4 of 6
I'm guessing its your browser. Try a different one to confirm.
post #5 of 6
I have Explorer 64-bit, perhaps that is the problem...
post #6 of 6
Tried it again just now and it worked fine...the computer gremlins and goonies at work i guess...biggrin.gif Thanks for the earlier help!
  Back to Forum: Forum Operations Center
