AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How to show receiver volume indicator on TV
post #1 of 4
I have a Sony LCD TV (HX750 Series) and a Sony Receiver (STR-DS3600ES).
When I am watching TV (input is HDMI 1) or using any other HDMI input, I cannot see the volume indicator on the TV.
Any suggestions?
thanks!
post #2 of 4
Have you ever seen it? This is a 6 year old AVR so it may not be possible. Check the AVR's Owner's manual to confirm. Otherwise, you may be able to get it by setting the HDMI-CEC feature on the TV (BraviaSync) to ON.
post #3 of 4
Nope, i've never seen it but it's been bugging me, so i thought i'd ask. the HDMI on the TV is set to ON, so I guess I'm outta luck.
thanks!
post #4 of 4
More than likely that receiver does not over volume overlay over HDMI. Very few receivers did back then.
You're probably out of luck.
