AVS › AVS Forum › Audio › Audio theory, Setup and Chat › YPAO™ R.S.C. (Reflected Sound Control) Vs. Audyssey XT32
post #1 of 4
The new Yamaha CX-A5000 separates has the “new” YPAO™ R.S.C. (Reflected Sound Control) Sound Optimization with Speaker Angle Measurement mic, is this as good as Audyssey XT32 which has always been said to be the best on the market?rolleyes.gif
http://usa.yamaha.com/products/audio-visual/aventage/cx-a5000_black_u/?mode=model
post #2 of 4
There isn't much info available on this yet, but from what I can tell, the "Reflected Sound Control" looks like it attempts to reduce the impact of early reflections. That is something no version of Audyssey attempts to do. RSC is also a multi-point measurement system with 8 measurement positions. I suppose they need that to do the "speaker angle measurements."
However, there is no information, (that I could find), on whether the YPAO aspect will EQ the bass. Previous iterations of YPAO have stopped EQing at 63 Hz. Audyssey XT32, and all versions of Audyssey above Audyssey 2EQ, will EQ the subwoofer channel to about 10 Hz, (depending on the capability of the subwoofer(s)). If YPAO with RSC does not improve on the bass EQ functionality of previous versions of YPAO, Audyssey will still have a HUGE advantage over YPAO, (IMO!)
Hopefully more information will become available soon on this.
Craig
post #3 of 4
At least for the last 2 years, the higher end YPAO includes Eq-ing down to 31 Hz.
post #4 of 4
the high end rxa yamahas have sub eq built in...I believe from the 2000 series on up. However my rxv773 has ypao rsc multi-point measure and a built in 7 band peq adjustable from 31-16khz, but no sub eq.
