Makemkv Question
post #1 of 41
Is makemkv capable of ripping full 1080p HD video and 7.1 HD audio whether it's DTS or Dolby?
post #2 of 41
Yes, it's the same media thats on the disc basically just dumped into an mkv container, by default MakeMKV takes Dolby/DTS 5.1 tracks you must manually select TrueHD/DTS-MA tracks you can un-do that in the settings I think so it defaults to HD audio instead.
post #3 of 41
Nice so it can rip at 7.1, fantastic. Does it sound just as excellent as on the hard copy?
post #4 of 41
It is exactly the same content so how is sounds depends only on how (and with what) you play it back.
post #5 of 41
makemkv does not alter the video or audio, it just rips selected portions and puts them back together in a mkv container. So yes the video and audio are of the exact same quality but you still need to be able to playback the formats, so your playback device has to support true-hd etc...
The mkv container is supported by most playback devices, but there are some out there that don't so make sure.
post #6 of 41
After you rip the MKV, you can change the order/add/delete audio tracks, chapters, and subtitles with MKVmerge.
post #7 of 41
What playback devices would you recommend? I have Windows 7.
Edited by mijotter - 7/7/13 at 8:25pm
post #8 of 41
Anyone?
post #9 of 41
If it requires HD audio pass-through then anything from Popcornhour or Dune line would do.
post #10 of 41
I have a quick audio format question. I'm new to the ripping thing and MakeMKV. All I'm getting from a flat screen in the living room is static. The video is OK. While in the ripping process I am faced with selecting audio tracks to keep or eliminate. All I'm interested is the english tracks. I am streaming to 2 locations, direct to a flat screen for the living room and through a AVR for the theater. In Shrek Forever After I am provided with 4 english audio tracks to select or de-select. TrueHD 7.1, DD 3/2+1, DD 2.0 and
DD 3/2+1 again. Not sure why 3/2+1 shows up twice. Anyway, what audio track will a flat screen pass or is this a setting in the borrowed WD media player I'm using to test with.
I will be using Dune players in the future.
post #11 of 41
If you're going to get DUNE players in the future, I would select the TrueHD for your AVR (bitstreamed), the first 3/2+1 (which is the core audio), and the DD 2.0 for your direct connect flat screen. DUNE players do not downmix TRUEHD at all, so you wouldn't get any sound directly to your flat screen, without an AVR.
The second 3/2+1 is very likely a commentary audio track, which is a waste of hard drive space, in my opinion.
post #12 of 41
What does "DD 3/2+1" mean?
post #13 of 41
Answering my own question 3 fronts 2 rears and sub (5.1)
post #14 of 41
If it's there I missed it but it would be nice if there was a button to "un-check all" so all you had to do is select what you want instead of the other way around.
post #15 of 41
Ok so all I want to do is build a media library on my HTPC and play it through my receiver to my theater room. Right now I have cat6 cables for the AVR, BD player that will be networked to the HTPC. HDMI going from AVR to HTPC as well. Do I have to purchase a separate device to play movies from the HTPC or is it something I download/buy and put it in the HTPC?
post #16 of 41
In the title menu...
right-click > Unselected All
post #17 of 41
Plex Media Center.
post #18 of 41
Well I want something that will be able to stream it in HD Audio and Video. From what I've read Plex cannot do the audio that I want...
post #19 of 41
That's odd. Plex Media Server is able to give me TrueHD, all the way down to Mono, with full Blu-Ray HD streaming to my DUNE player.
post #20 of 41
Well following your advice I have been selecting all three until I ran into Hancock. That seems to have a host of issues to overcome. It has two versions on one disc and only two English audio options "TrueHD 5.1 and DD 3/2+1. No DD 2.0. So how is that going to play direct to a flat screen through a Dune?
post #21 of 41
You'll be fine with 3/2+1 directly to your flat screen. If you only had TrueHD selected, you will not get any sound going directly to your flat screen, since TrueHD cannot be decoded without an AVR connected to the DUNE.
post #22 of 41
You can get 7.1 Dolby TruHD and DTS-HD sound?
post #23 of 41
Yes. My DUNE player picks up TrueHD and DTS-HD (MA)
post #24 of 41
Re-ripped just to make sure. I checked 3/2+1 and TrueHD. Still no sound from the flat screen. I checked settings in the WD player I borrowed (really nothing much to set in it).
I'll have a look in the LG's audio settings just as soon as my son can be ripped away from Xbox.
post #25 of 41
from the player, you need to switch the movie's (not the WDTV player) audio setting to 5.1 Surround. It won't work under TrueHD.
post #26 of 41
In Windows Media player? If so, I don't see the option. In the WDTV there is only the option of the sound source HDMI or optical.
post #27 of 41
While you're watching the movie, you should be able to switch from the available audio tracks of the film.
Edited by L33TX43RT - 7/12/13 at 10:07pm
post #28 of 41
From where? WDTV, the display, WMP or WMC???
On someone elses suggestion I downloaded and installed CCCP. Then my rips started becoming available to WMP. When that happened they also started showing up on the WD media player. Now all my rips have perfect video but the audio is hit or miss.
The person who I am setting this up for is autistic and can't do any more then point and click. If it requires any more then that then it isn't goint to happen. It should not be this hard.
post #29 of 41
Can you re-open a MKV? For whatever reason the BD "Transformers 2" is working from the flat screen. If I could re-open it to see what audio selections I made with that one, perhaps my problem will be solved.
post #30 of 41
Plex Media Server can handle HD audio just fine. Whether you get HD audio just depends on the client that you use. There is a a new Popcorn Hour app and also a user made Dune app which should support HD audio.
