AVS › AVS Forum › Other Areas of Interest › Camcorders › MiniDV and Hi8 adapters
post #1 of 4
I need some type of way to play these tapes and really can't find anything online. There are VHS-C video tape adapter but I read that MiniDV and Hi8 won't play in those.
Can anyone help me find a cheapest alternate way to be able to play these?
post #2 of 4
You need a MiniDV camcorder or deck to play MiniDV tapes. You need Hi8 or Digital8 camcorder or deck to play Hi8 tapes. Decks are often multiscanning, but camcorders usually not.
post #3 of 4
Do you have link to any of those?
post #4 of 4
Google? eBay?
What I meant by multiscanning is you need a 60 Hz ("NTSC") camcorder to play 60 Hz tape. Decks usually play both 50 Hz ("PAL") and NTSC, but you need to double-check. Decks are expensive anyway, just get a used camcorder and ingest into computer via FireWire (AFAIK Digital8 uses FireWire, Hi8 camcorder uses analog output. All MiniDV use FireWire). Thus you need a computer with FireWire port. You can get a FireWire riser card for about $15.
  Back to Forum: Camcorders
