AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Big space to fill... need some suggestions.
post #1 of 6
My living room has a sloped ceiling leading up to about 18 in the back and is open to the kitchen. The total cubic feet of the area is around 6000. I currently have an old Velodyne CT-150 that is still faithfully pumping out bass... unfortunately nothing below around 32hz. My hope is to get something that is flat down to at least 20hz.
I currently listen at around -10 below reference and have around 1k to spend on the sub. I have been looking at dual LFM-1 Plus's because it seems that a dual sub configuration would be needed to fill the space. That said I have no problem with only one sub if it can crank out the decibels on the low end. My issue is I am overwhelmed with decisions. The LFM-1 Plus's seem to well received, but when you throw in SVS, PSA, Rythmik etc. it seems the list never stops growing.
I guess the question is do i need two subs or can someone recommend single sub that would meet my needs?
Thanks in advance.
post #2 of 6
Do you find the bass to be uneven throughout the room or at the listening position(s) with a single sub? Despite the lack of extension, do you find that the Velodyne has enough output?
post #3 of 6
Based on your budget, I would go dual Rythmik LV12R's for 1070.00 shipped. I think it would be best to have dual subs and possibly keep the velodyne hooked up for smoothing capabilites.
post #4 of 6
There is a small range that is a little on the boomy side at the listening position, but over all it is fairly even. The Velodyne definitely has the output. I have never felt that it wouldn't go loud enough.
Taking a look at the Ryhmik's now. You feel these would provide a stronger lower end than the Outlaws?
post #5 of 6
Not the EX ,but I believe they would have the same extension as the plus and have better SQ over both. The EX is a solid sub too, just higher than your budget. However all three options are great and you would probably be happy with any of them. I would do some research, email the companies, and go with that provides the best customer service, warranty, and price.
Edited by basshead81 - 7/5/13 at 7:41am
post #6 of 6
+1 on the dual LVR's. Outlaw would be good also! I used to own a couple of CT/CHT-150's... you're going to notice a huge difference in extension and you're really going to like it! wink.gif Be carful trying to integrate the CT though, it will most likely drag your low-end gain down at a certain point.
Edited by steve nn - 7/5/13 at 8:46am
