AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Combination Audio/Visual receiver?
post #1 of 4
I have wired my house x 2 Cat5/x2 Cat6, + x1 RG59 to 5 different room locations for video. Two of these rooms also have dual channel speakers for whole home audio.
Since I need a matrix to distribute the video anyway, are there systems that can distribute both video & audio, and be used as a multizone audio system for music?
Are there any systems that would utilize the existing Cat6 cables without needing baluns?
post #2 of 4
Short answer is not anything that would be considered DIY or "budget". Those systems are much cheaper if installed separately, but they can certainly share sources. The remote / control methods are very different, too.
post #3 of 4
In the rooms with whole home audio, are your TVs connected to the whole house audio speakers? If they were you could use something like a roku or apple tv to stream your music.
post #4 of 4
Thanks Jautor, it did seem quite a bit more complicated than your basic matrix or 6/6 zone audio system.
And no Virtus, the speakers are home runned.
  Back to Forum: Home A/V Distribution
